Resposta aceitaThe controller itself (RDC6445G) does not define the real cutting speed limit. The machine mechanics, laser power, and material determine the actual maximum cutting speed.
For very thin materials (paper, thin plastic, thin wood ):
200–400 mm/s → common fast cutting
400–600 mm/s → possible on high-quality machines
>600 mm/s → rare; usually engraving speeds
- i m using 250 speed and power 11% 250 for engraving mdf (5mm)
If engraving is too dark
i try:
Speed: 300 mm/s
Power: 9–10%
Your answer is detailed and professional, which is very helpful to me. Thank you
