Why can't my RDC6442G system connect to Windows 10?
2C3A94E9
Everything was normal before. I changed my computer to Windows 10, but I still couldn't connect to the RDC6442G control system. What's the reason?
  • If you are using a USB connection, first check whether the USB driver is properly installed, or try a different USB port.
  • Confirm that the software has selected the correct mainboard model for connection, and verify whether the communication method is Ethernet or USB.
    1. Incorrect network IP settings—check whether the mainboard IP address has been set correctly.
    2. The connection mode has not been correctly set to network—ensure it is configured for network connection.
    3. The Ethernet cable is not connected between the mainboard and the computer, or the cable is faulty—replace the cable and ensure the network connection is functional.
    4. The USB cable is not connected between the mainboard and the computer, or the cable is faulty—replace the USB cable and ensure the USB connection is functional.
    5. The USB driver has not been properly installed—install the USB driver correctly.
    6. The connection mode has not been correctly set to USB—configure the connection mode to USB.
