Resposta aceita
My CO₂ laser power suddenly dropped. I checked the optical path and water temperature, and there does not seem to be any problem. There is a current indicator on the side of the machine. When I test at maximum power in pulsed mode, the indicator shows 20, but when I set the power to 65% on the computer, the current only shows 04. It feels like there might be a software issue limiting the power. Any ideas?
Resposta aceita
Is the working current too high? When the working current of CO2 laser tube exceeds 10% of the allowable current, it will lead to an exacerbation of power reduction. Unstable current can also affect the power output of the laser tube.
