The RDC6585G control system has weak laser output and cannot control the light
66C40858
I have a CO2 laser cutting machine that is paired with the RDC6585G control system. When I operate it, the laser output is noticeably weak, and there is no response when trying to adjust the power or control the light intensity. The system cannot achieve normal light control operation.
  • 689EDFDD
    The laser simulation voltage is too high, and the simulation voltage of UR1 and UR2 should be readjusted to around 4.5V
    • I adjusted the voltage and now I can control the laser normally. Thank you
  • Check the power settings in the software or controller. The minimum power is not equal to 0, and the maximum power is limited to a very low value
