How can I convert a CUT file to an editable AI file?
1915DD20
Does anyone know how to convert a CUT file to an AI file that I can edit? Thanks in advance!
  • 85B3C4D7
    Can You Convert .CUT Files for AI Editing? It Depends.
    .CUT isn't a standard format. Here's what you can do based on where the file came from:
    1. From CorelDRAW
    Most .CUT files are just CDR files with a different extension. Rename .cut to .cdr, open in CorelDRAW, and export as AI/EPS/PDF — fully editable.
    2. From Laser Software (RDWorks, LaserCut, etc.)
    These are toolpaths, not designs. They don't convert directly to AI. Export as DXF or PLT from the original software, then open in Illustrator and touch up manually. Note: curves may become polylines, layers/colors will drop, and text won't be editable.
    3. From Legacy/Proprietary Software
    Private format with no export option. No conversion possible — you'll need to redraw it.
    • Thank you
  • You can import the graphic file into the cutting software VCutWork, then go to the software menu: File → Export as AI format.
