Resposta aceitaDid you press the [Stop] button during [capacitor calibration]? Is the cutting head positioned too high above the metal plate? Additionally, the upper or lower limit switches may have been triggered.
My fiber laser cutting machine uses the RDC6563FG control system. During capacitor calibration, there was a failure, and the answers to the information I found online were inconsistent. Therefore, I sought help from this community. Thank you all!
Can the motor operate normally?
Check the voltage. It will be affected if it is too high or too low
