Why isn't the camera lighting of RDV6332M controller on?
4FD8B9AF
My device is using the RDV6332M control system, and I was about to perform visual positioning, but I found that the camera lighting was never on. Whether switching the light source switch in the software or repeatedly restarting the device, the lighting system still does not respond. Any suggestions? Thanks in advance!
  • Is the wiring correct? Maybe it is reversed
    • I rewired it, it's normal now
  • I won’t hesitate to check if the power light is broken.
