Why does the RDC8445S controller automatically reset to the origin?
EFC19E41
My CO2 laser cutting machine uses the RDC8445S control system. Today, I found an abnormality while operating it. Every time the processing program starts, the originally set processing point will automatically reset to the equipment origin. Whether it is continuous machining or individual workpiece operation, the system will forcibly return to the starting coordinates at the moment of startup, causing the machining path to be interrupted. What is the reason for this? Thank you in advance for your suggestions.
  • 0B5DC9F3
    Based on the following four items, we hope to help you solve the problem
    1. Abnormal reset parameters
    2. Panel reset button malfunction
    3. The power supply voltage is unstable and under voltage.
    4. Program firmware malfunction
    • Thank you, the reset parameters were incorrect and have been corrected
  • If it automatically returns to its original position upon startup, it may be because you have set the default startup reset function. Please check and it is possible that you have overlooked it
    • It's a matter of resetting parameters. Thank you for your answer
