Resposta aceitaI suggest you check according to the following items. Good luck!
1. Has the communication between the motherboard and panel failed
2. Has a very small jog distance been set?
3. Has hard limit protection been enabled and triggered
4. Has a large jog distance been set?
5. Is the button acceleration too small, causing the buffering deceleration to be too long
The jog distance setting is too small, it has been adjusted. Thank you
