Why does the planned position and actual position of the RDV6555G controller not match the coordinates?
6E97F951
My cutting equipment has a troublesome problem, and the controller model used in conjunction with it is RDV6555G. The position planned by the system does not match the actual operating position of the machine. At the beginning of processing, the graphic position displayed in the software interface appears completely normal, and the preview path is also normal. However, during actual operation, the cutting or carving position of the machine is clearly offset. Thank you for any suggestions.
  • Caspar
    I suggest you follow the following steps for troubleshooting, hoping it will be helpful to you:
    1. Is the transmission of the associated motor encoder interfered with
    2. Is the electronic gear ratio of the server set to correspond
    3. Is the number of pulses consistent
    4. Calculate whether the step distance is normal based on the lead and pulse count
    5. Is the lead consistent with the actual hardware
    • The issue with the step distance has been resolved. Thank you, Caspar
  • If the machine does not return to zero after moving, the coordinates of the controller will be incorrect.
    Press the control panel Reset to automatically return the machine to its original position before starting processing
