When using RDWorksV8 for cutting, the graphic font becomes skewed
64E0A84B
When I was using RDWorksV8 for cutting today, I imported the file and everything was normal. However, when I cut it out, I found that the font had an unexpected skew. I checked the relevant parameters and there was no problem. Does anyone know where the problem lies? Thanks in advance!
Respostas (3)
  • Spark
    You should check the focusing lens. It might not be installed properly
    3
    • I reinstalled the focusing lens and everything is now normal. Thank you for your reply
  • Check if the font is italic, double-click the font to see, if it is italic, change it back
    • not italic
  • I suggest you verify whether the imported file scale has been skewed
