What is the reason for the unsuccessful reset of RDC6555G?
The control system used for my device is RDC6555G, and I encountered a problem during the reset operation. After a brief flashing message was displayed on the panel, there was no response immediately, and the controller was unable to continue the reset action. What is the reason for this?
Check whether the power supply or voltage is abnormal. Reset failure is common in situations where the power supply is unstable or the voltage is insufficient. Check if the power input of the control system is stable and ensure that the rated voltage meets the requirements. If necessary, replace the voltage regulator or check for loose wiring.
1Responder
