The power indicator light of my controller is not illuminated, RDC6332NM
Maria
It's strange. Today, when I tried to operate the machine, the green power indicator light on the controller didn't light up at all. The device showed no signs of power-on startup and was in a completely powered-off state. It's an RDC6332NM. What could be the problem?
  • 1. Check if the wiring is correct.
    2. Then check if the indicator light is working properly.
    3. Use a multimeter to test for abnormal input voltage.
    • I replaced the power supply and it can now work normally
  • Check all cables and connectors between the power input and the controller for obvious signs of burning, breakage, looseness, or detachment, and re tighten the power input terminals of the controller and the machine power output terminals (power-off operation).
