Resposta aceitaHave you checked if jumbo frames are enabled in the network configuration
I am using the visual positioning (Mark point recognition) function of the RDD6616U vibration knife equipment. During the calibration or recognition process, the camera has successfully recognized the Mark point (or within the effective area), but the machine did not perform the expected alignment or cutting action subsequently. Who can help me? Thanks in advance.
After inspection, the giant frame was not enabled and is now normal. Thank you
