RDVisionWorks isn't detecting edges,What should I do?
Abel
My image quality is fine, but edge detection isn't working in RDVisionWorks. Which key parameters need adjustment? Thanks in advance for your help.
Respostas (3)
  • Marshall
    The following situations may have caused the issue: too high filtering, not drawing the effective area, incorrect width and height of the contour, removing the black border, and trying to select the effective area with a box
    • After my investigation, it was found to be a filtering issue. It is now functioning normally. Thank you for your response
  • I think the edge detection parameters you set are incorrect, which led to this situation
  • Has the brightness of the light source been adjusted?
    • I have already adjusted it
