Resposta aceitaThe reason may be that your encoder resolution is not set correctly. Please check
Has anyone else encountered this issue? My cutting machine is equipped with an RDV6555G control system, where the Y-axis drive has insufficient power output, while the X-axis is functioning normally. Could this be a hardware or software problem?
I feel like this is a problem with the Y-axis mechanical system, and I don't know much about it
Check the movement of the Y-axis, which is usually caused by mechanical resistance. Check if there is any damage or other issues with the moving parts
I reset the encoder resolution parameter, and now the Y-axis power is normal
