Resposta aceitaAfter successful calibration, align the standard grid generated by the software with the grid taken in the photo, and check the degree of overlap. In the case of full frame calibration, the normal cross XY offset value is less than 1mm. Click on the import image to import the uncorrected image (saved in the temp folder in the file directory), and then load the corners to see if the corner positions are added correctly
Okay, thank you for your answer
