Resposta aceitaUse a multimeter to measure the 24V and GND terminals on the motherboard. The voltage should be around 23–25V.
Check if the motherboard's Power/Run indicator light is illuminated.
Possible scenarios:
No 24V → Power supply unit failure or circuit break.
Voltage normal but light not on → Motherboard may be damaged.
The power failure issue has been resolved. Thank you
