The laser head is not operating at the correct position. The laser head must be positioned at the bottommost part near the Y-axis direction (the end closer to the person).
I operate the RDC6442S control system, with a graphic exceeding the screen size, and I select automatic blocking. After the laser cuts horizontally in the X-axis direction, it does not emit light. The U-axis starts feeding material, and when it reaches a certain length, the laser emits light for cutting, and then stops. I don't know where the problem lies.
Thank you, I have already resolved the issue
