RDC6442G controller laser head does not return to the positioning point
64E13E89
When using the RDC6442G controller for processing, the laser head automatically returns to the set positioning point after processing, and the process is normal. But after I press the exit or end task button, the laser head no longer returns to the positioning point and stays at the processing end position. I don't understand why this is happening? Can anyone give me advice? Thank you!
Respostas (3)
  • Ruidatech5
    You can try changing the setting in RDWorks:
    Go to:
    Position Setting
    → Set it to either:
    • Current Position, or
    • Machine Zero (X0, Y0)
    If it is set to Current Position, the laser head will return to the point where you started the job.
    If it is set to Machine Zero (X0 Y0), the laser head will return to the machine’s origin (home position) after finishing.
    Adjust this setting and test again — this usually solves the issue.
    • Thank you for your response.
  • Try holding down the 'Switch' button and then pressing the 'Exit' button to go back to the waypoint and tell me what happened
  • Enter the settings interface of RDWorksV8 or the control panel, search for options related to "return to starting point after completing task" or "return to zero", and ensure that the option is enabled and configured correctly.
