Resposta aceita1. After pressing the switch, observe whether the contacts of the relay are correctly engaged. If the contacts switch normally, it indicates that the switching function is normal
2. First, test without enabling the hardware limit. If the machine can move normally, it indicates that the limit polarity is set incorrectly.
3. The Z-axis format can be set to a larger value, such as 10000
4. Set the motion mode to continuous motion mode (with a jog distance of 0) and test if the motion is normal
I have carefully investigated and found that the limit polarity setting was incorrect. It has now been restored to normal. Thank you Payson
