RDC6332NM controller alarm light does not respond when connected to relay alarm
2C3A94E9
My device is paired with the RDC6332NM control system. Every time the system triggers an alarm, the relay should trigger the alarm light to flash, but in reality, the alarm light never lights up. Checked the electrical connection between the relay and the alarm light to ensure that there is no looseness or disconnection, and also confirmed that the power supply of the alarm light and relay is normal. What went wrong? Who can help me? Thank you!
  • 634D6613
    Check if the working voltage of the alarm light matches the output voltage of the relay. If the voltage output of the relay is insufficient or too high, the alarm light may not work properly.
    • Checked and reset, thank you
  • Please check if the reset alarm and alarm delay time have been set
