pressed the emergency button now has file transfer signal
Canz
i pressed the emergency button now has file transfer from a computer to the laser clip is showing and everytime i restart my laser it always shows this and i dont know how to get rid of it.. please help..
Respostas (3)
  • Hello, according to the pictures you provided, there is an HMI interface that cannot be accessed. The approximate analysis and troubleshooting methods are as follows:
    1. Power off and restart
    Turn off the entire machine for 3 minutes and then turn it back on to eliminate temporary shutdowns.
    2. Check the controller power supply voltage
    Check if the output of the switching power supply is 24V, if it is lower than standard, you can directly replace the power supply to solve the problem.
    3, caused by abnormal test equipment factors
    Pull out all the port connections, leaving only the controller and the screen, and then turn it on; if you can enter the interface, it means the peripheral is short-circuited, reconnect it one by one to find the fault point.
    4. Reconnect the screen cable
    Unplug the power cord and check if there are bent pins or oxidation.
    5. Determine the problem with the HMI panel or controller
    If the screen / motherboard of the same model can display normally, it means that the screen is broken, and if it still does not enter the interface, it may be that the motherboard firmware / hardware is broken.
  • I don't quite understand what your problem is, specifically what software and device it is. Please upload a screenshot of the malfunction to take a look
    • Here are my pictures
  • Hello, due to the lack of comprehensive information, please provide the controller model and a screenshot or video of the screen, otherwise, it is impossible to determine the specific reason.
