Resposta aceitaDaily Checklist (Before Startup Each Day)
1. Lens cleanliness: Inspect protective lens, focusing lens, collimating lens, and QBH fiber connector. Ensure they are free of dust, oil stains, and spatter.
2. Correct installation: Verify that the welding and cleaning focusing lenses are installed in the correct orientation and position, with retaining rings securely tightened.
3. Normal temperature: Use the back of your hand to sense the temperature of the scale tube (cooling water pipe). It should be within the 25±2℃ range, with no air bubbles trapped.
4. Galvo mirror condition: Check that the galvo mirror surface shows no signs of burning or coating peeling. During manual jogging, movement should be smooth with no abnormal noise.
