My fiber laser cutter,RDC6563FG-LITE,the cutting head has a large following error
Cati
My fiber laser cutting machine is equipped with the RDC6563FG-LITE control system. During operation, there is a significant tracking error in the cutting head and the focus position is inaccurate. Can someone help me? esteem it  a favor!
  • Payson
    If the "following error too large" alarm is frequently triggered during the cutting process, the maximum following error parameter should be increased.
    • I increased this parameter, and the effect is much better
  • Check if the Z-axis lifting mechanism (screw, guide rail, rack and pinion) under the cutting head is loose, worn, rusted or lacks lubrication, which is a common cause.
    • All of these are fine, it's a matter of following the error parameters
