Resposta aceitaReset the format size. Also, is the safe distance value set reasonable? If it is unreasonable, it needs to be reset.
I started the processing, but the double beam equipment suddenly malfunctioned during processing, with one fast and one slow, causing an instant deviation and collision with the machine. I immediately stopped the processing. How can I solve this problem?
Ensure that the coordinate system used by the controller is correct, particularly verifying that the machine’s working coordinate systems (such as the machine tool coordinate system and workpiece coordinate system) have been set up correctly. Additionally, check the motion path planning for the dual gantries to ensure there are no unreasonable overlaps or intersecting paths that could cause both gantries to move to the same position simultaneously.
