How to set the RDD6616U Ruida system to not lift the knife at corners?
Charlotte
I am using the Ruida system, RDD6616U, How can I set the knife not to lift at the corner? How to set parameters?
How to set the RDD6616 Ruida system to not lift the knife at corners?
Resposta (1)
  • Clarence
    1. Go to Software - Parameter Settings - Optimize Parameters, select the corresponding tool and set the lifting angle to 180 °.
    2. Go back to User Parameters - Processing Parameters and set the tool lifting angle to 180 °
    I hope it will be useful to you.
    • I succeeded, thank you very much!
