During the cutting process of RDD6616U, the tool is lifted to the zero point coordinate
4C0D4BA9
I am planning to use the RDD6616U controller for cutting, and I have set the tool lifting coordinates to ensure that the tool can be lifted to the designated position in non cutting state. However, during the actual cutting process, the tool unexpectedly lifted to the zero coordinate position. Why did this abnormal phenomenon occur? Thank you in advance for your help!
  • BAF58914
    Enter User Parameters - Processing Parameters, check the empty distance setting value. If the empty distance between two graphics is greater than the empty distance, it will be lifted to the zero point coordinate.
  • There may be hardware signal interference. Check whether the limit switches of each axis are loose or if the wiring is damaged. During non-processing, manually trigger the limit switches to verify if the control system responds normally and displays an overrun alarm. If the signal is intermittent, it is recommended to replace the switches.
