RDC8445S controller, why can't the multi-point positioning function be used?
B70F0980
I have a CO2 laser cutting machine and I found that the U-axis cannot use the multi-point positioning function properly when working as a rotating axis. Whenever I try to set multiple positioning points, the system fails to respond and the positioning operation cannot be completed. Who can help me solve this problem? Thanks!
Antwoord (1)
  • The U-axis does not support multi-point positioning function when rotating the axis
    • Oh, I see
