Why does the dual blade of RDD6584G control system vibrate?
85B3C4D7
My machine is equipped with an RDD6584G controller. Today, I encountered a problem where there was significant vibration during dual blade cutting, resulting in a decrease in overall stability and machining accuracy. How can I correct this issue?
  • C9150BFF
    Perhaps you have activated the roller vibration, please turn it off
    • Closed, vibration disappears
  • Is your blade securely installed? If the double blade is not securely installed or the connection part of the blade is loose, it may cause vibration during operation. Check if the fixed components of the blade are securely installed and if there are any looseness or sources of vibration.
