RDD6584G control system cyclic processing without feeding
I operated the vibration knife control system RDD6584G for cyclic processing. In cyclic mode, although the equipment was able to repeat the processing path, the feeding mechanism remained inactive and the material remained in its original position. I stopped the machine to check the feeding device and did not find any abnormalities. Any ideas? Thanks!
I used it normally after changing the parameters, thank you
