Принятый ответHave you replaced any components such as capacitive sensors? If so, you need to perform capacitance calibration again.
I haven't operated this fiber laser cutting machine for a while. I used the RDC6563FG-LITE controller and started it up today. I found that there is a significant deviation between the following height and the target height, and the cutting accuracy is not up to standard.
Check if the sensor is damaged, contaminated, or improperly installed, which may cause data deviation.
I have conducted capacitance calibration again, and the machining accuracy is now normal. Thank you for your reply
