Принятый ответCheck if your panel matches the motherboard product model (model, firmware, non-standard)
When I was operating the RDC6585G control system and reading files on the panel, after about 30 seconds of operation, the screen prompted "Communication failure" and data transmission failed to complete. Can anyone help provide a solution? Thank you!
Check if the communication cables between the panel and motherboard are functioning properly, and if the ports are securely plugged in?
Check in RDWorks: Open file → Simulate run → Ensure graphics and paths are correct
After reading the motherboard information, it was found that the model did not match. Replace the corresponding panel to restore normal operation
