Принятый ответIn the manufacturer's settings, check the Z-axis parameters, mainly the maximum speed, takeoff speed, acceleration, and emergency stop acceleration that have not been adjusted properly. Please readjust them.
I have a CO2 cutting machine equipped with a Ruida controller, model RDC6585G. I encountered a strange phenomenon: when I press Z- or Z+ for a longer duration (about 3-4S), the Z-axis will keep moving downwards or upwards; pressing for a shorter duration works normally. Is this a normal phenomenon? Or do I need to adjust something? Any suggestions would be appreciated!
The Z-axis has two behaviors: "jog" and "continuous jog". Short press Z+/Z-
→ The controller performs a small jog step and stops once it moves
Long press for about 3-4 seconds or more
→ The controller automatically switches to continuous jog mode,
As long as you don't let go, the Z-axis will keep moving up or down
I understand, thank you
