How to reset the RDD6584G vibrating blade touch screen to factory settings?
B2A05ACE
I have been using the RDD6584G vibrating knife control system for some time now. Recently, I've been feeling that something isn't quite right during processing, and the machine parameters seem to be messed up. I want to reset to factory settings, which should solve the problem
  • Hello
    1.On the main page of the control panel, click the [Device] button. The following screen will be displayed.
    2.Click the [Set factory para] button and enter the password. This will back up all your current manufacturer/user parameters for future use with [Set default para] to apply the backup.
    Before performing this operation, make sure all parameters have been fully commissioned and verified as correct. Otherwise, the backup will contain incorrect parameters.
    Please download the user manual from the "Data Download" section at:
    https://www.rdacs.com/en/product-detail/rdd6584g.html
    The instructions for restoring factory settings are in Section 8.2.
    • Thank you for your response
  • Resetting to factory settings will erase all user parameters. It is recommended to back up data before proceeding
    • Yeah, But I have to choose to think like this, thank you
