The RDC6612U controller failed to recognize during the large-format matching test
01CEB9B5
My device uses the Ruida control system RDC6612U. During the large-format matching test, the target device was not recognized. At the start of the test, the system passed its self-check, but after connecting the large-format module, the controller displayed an inability to recognize the signal, causing the matching process to be interrupted. Any suggestions? Thank you all!
  • Thomas
    Check whether "Common Edge" is selected.
    • Yes, I have cancelled this option
  • What materials do you process? If it is a mirror metal or high gloss film material, surface reflection will interfere with camera image acquisition and affect recognition accuracy.
