RDV6563FG controller experiences air pressure alarm
1C2920B1
My fiber laser cutting machine uses the RDV6563FG control system. Today, while operating, I noticed that the air pressure alarm was constantly flashing on the device screen, the cylinder was acting abnormally, and the adsorption was unstable, resulting in the inability to grasp the workpiece properly. How to solve it? Thanks in advance!
  • Gary
    When the motherboard detects that the air pressure alarm input (universal input port I11) is at a low level, the motherboard will generate an air pressure alarm. If it is in processing, the processing will be paused. Please eliminate the alarm.
    • thanks!
  • Please check the pressure reducing valve or filter. Improper adjustment of the pressure reducing valve, oil stains inside causing the valve core to jam, or clogged filter can all cause low or unstable output air pressure.
