How to set cutting points for RDWorksV8?
00676C66
I have a simple question, how to set the cutting point in RDWorksV8? Thanks in advance!
  • Gary
    Click on Edit, select Set Cutting Point, double-click on the object to display all cutting points, double-click on the cutting point to select the desired direction and position
    • Okay
  • What do you mean by cutting point? Could you give more details?
