5F63EBA4
Resposta aceita
Resposta aceitaGo to Menu > Settings > System Settings
Uncheck "Allow only one instance to run"
Double-click the V8 shortcut again to launch a new window
How to use RDWorksV8 for multi window operation or set up dual opening, with one computer controlling multiple devices?
thanks
