Zaakceptowana odpowiedźYou check the following items, and your problems are usually caused by these reasons
1. The software does not set the graphic positioning position to: current position; But it was set as the mechanical origin or absolute coordinates
2. The positioning key on the operation panel is damaged, causing it to malfunction. It can be replaced with a new panel for testing
3. The control card has set the multi positioning point function. After setting the multi positioning point function, the positioning keys on the panel will not work, and the system will process according to the set positions of the multi positioning points. If you want to restore the function of the positioning key on the control panel, you need to disable the multi positioning point function in the menu of the control panel (this function is applicable to Ruida series controllers)
I have set up the multi location feature, but I have disabled it. It can now be used normally. Sorry, I only replied to you now. Thank you!
