RDC8445S for co2 laser, reset button malfunction
Robert Evans
My co2 cutting machine has been upgraded with the Ruida control system, model RDC8445S. When I press the reset button, there is no response. What could be causing this? Help!
  • roy
    I suggest you check the following items:
    1. The software manufacturer's parameter for enabling motor reset is not activated
    2. The panel button function is damaged
    3. User parameter power-on reset is not enabled
    • The reason is that the power on reset enable was not turned on, but after it was turned on, the panel can now be used normally
  • First, inspect the button itself for any damage, wear, spring failure, or stuck internal mechanical structure. Then, check the wiring for correctness.
    • These are all correct, the reason is that the power on reset enable was not turned on
