RDC8445S controller multi-point positioning function cannot be used
EFC19E41
My cutting machine uses a ruida controller, RDC8445S, I set the U-axis as the rotation axis for cylindrical machining, but I found an issue: once the rotation axis mode is enabled, the normal multi-point positioning function cannot be used. Whether selecting multi-point positioning in the panel or software, the device does not perform the corresponding action. Does anyone know what's going on? Thank you!
  • Spark
    The U-axis does not support multi-point positioning function when rotating the axis
    • Oh, I see. Thank you
  • I suggest you check if the reset speed setting in the user parameters is correct, and then check if the x-axis limit and motherboard limit indicator lights are abnormal
