Press and hold the 'Switch' button, then press the 'Exit' button to return to the designated location.
The control system used for my CO2 laser equipment is RDC6445G, which can return to the set positioning point after processing is completed. However, when the point exited, the laser head did not return to the designated location as expected. This phenomenon makes me very puzzled. What is the reason?
thanks
