Why does the RDV6445G controller have a deviation in cutting the cross?
BAF58914
Hello everyone, I have encountered a new problem again, RDV6445G, The cross shaped pattern cut always has deviations, and the distance of deviation varies greatly, making it difficult to fix. I checked the alignment of the machine to ensure that there are no problems with the material and laser head position. Who can help me solve it? Thank you in advance!
Antwoorden (2)
  • Check if the hardware belt is loose or missing steps, and if the motor clearance is too large
    • There is a problem with the guide rail. After reinstalling and aligning it, it works normally
  • If the step distance (pulse equivalent) in the controller is not calibrated, it will cause errors in the X and Y axis size ratios, manifested as cross horizontal and vertical length or intersection position deviation.
