Geaccepteerd antwoordSet the acceleration too fast, try reducing the machining acceleration and observe what happens.
When I was using the RDV6555G control system for machining, the power output of the equipment was normal when running on short straight lines, and the machining effect was stable without any obvious abnormalities. However, when the processing path becomes a longer straight line, the actual output power is significantly lighter and the material cannot be cut through. I tested with the same materials separately, but the problem still persists. Who can give me advice? Thanks.
The most common situation is when the bus voltage drops, accelerating for a long time → the current continues to be high → the bus electrolytic capacitor cannot support it → the voltage drops → the controller mistakenly believes that the battery is dead → the power is reduced
OK, Thank you, the issue has been resolved
