The RDC6442G control system experiences incorrect movements during the dual-head mutual movement
6186B983
My CO2 cutting machine uses a Ruida controller, model RDC6442G. During processing, when the dual-head mutual movement function is enabled, the two cutting heads exhibit a phenomenon of disordered movement direction, resulting in a deviation of the processing trajectory and affecting the finished product effect
Antwoorden (3)
  • Ignativs
    When enabling dual head mutual displacement, it is necessary to enable the XYZ three-axis power on reset and find the correct coordinate system for each of the XYZ axes. In addition, after misalignment or mirroring the array, the graphic data may change, and mutual displacement may not be optimal.
    • Thank you for your help, I have already resolved it.
  • I suggest you prioritize checking issues related to physical and electrical connections, such as power supply problems, motor wiring, and encoder wiring issues. I have found that many malfunctions are caused by errors in these basic aspects.
    3
  • Please check if the A/B laser ports are connected incorrectly. I have made this mistake before, but of course, your problem may not be due to this
