The laser head always hits the sidebar
5C4692A9
The laser head functions normally during startup and reset, returning to the correct position each time. However, after completing an engraving or cutting job, the head moves to the top-left corner as expected but strikes the side bar before reaching its homing position.How to solve it?
Antwoorden (3)
  • Go to "Manufacturer Parameters" and check the direction polarity for X and Y axes. This setting determines which direction the machine moves to find the limit switches during reset. If it opposes your software origin setting, a crash may occur.
  • Does the machine have a small metal strip hanging down beside the laser head to trigger the limit switch? If so, check that it isn't bent—it should be perfectly vertical.
  • Adjust the homing sensor/limit switch position by moving it approximately 2 mm higher and closer.
