Geaccepteerd antwoordYou can try changing the setting in RDWorks:
Go to:
Position Setting
→ Set it to either:
Current Position, or
Machine Zero (X0, Y0)
If it is set to Current Position, the laser head will return to the point where you started the job.
If it is set to Machine Zero (X0 Y0), the laser head will return to the machine’s origin (home position) after finishing.
Adjust this setting and test again — this usually solves the issue.
Thank you for your response.
