Geaccepteerd antwoordYou can check whether the "Enable Reset" option is checked for the U-axis, which is not used in the factory parameters
I have a CO2 laser cutting machine that uses the RDC8445S control system. When performing a reset to zero operation on the X-axis, its travel speed is abnormally slow, significantly lower than the standard reset speed initially set by the equipment. Any suggestions? Thanks in advance!
Please check if the reset speed setting is correct
I don't know when I chose this. I removed it, and it's normal now. Thank you for reminding me
