Based on the described issue, it is normal for HMI 4-5 to be around 5V. Please provide the problematic symptoms of the HMI: Could you share photos or videos of the HMI when it's malfunctioning? If unavailable, you can also test the connectivity of the HMI's connection points (the interface between the mainboard and the HMI) using the continuity test function of a multimeter for 1-1, 2-2, 3-3, 4-4, and 5-5. If any of these connections fail to conduct, the HMI cable is likely damaged.
